Ga door naar hoofdinhoud
Turtle Beach Elite 800 Audio Board Replacement
Wat je nodig hebt
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: stap 1, afbeelding 1 van 2 Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: stap 1, afbeelding 2 van 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: stap 2, afbeelding 1 van 2 Turtle Beach Elite 800 Audio Board Replacement, Audio Board: stap 2, afbeelding 2 van 2
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: stap 3, afbeelding 1 van 2 Turtle Beach Elite 800 Audio Board Replacement: stap 3, afbeelding 2 van 2
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: stap 4, afbeelding 1 van 3 Turtle Beach Elite 800 Audio Board Replacement: stap 4, afbeelding 2 van 3 Turtle Beach Elite 800 Audio Board Replacement: stap 4, afbeelding 3 van 3
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
Conclusie
Johnny Lofton
861 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 1,945
