Ga door naar hoofdinhoud
Turtle Beach Ear Force XO Four Speaker Cone Replacement
Wat je nodig hebt
  1. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Ear Cushion: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Jimmy
    $7.95
    Koop
    • Insert a flat metal object (such as iFixit's Jimmy tool) between the green and black plastic portions of the headset.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 2, afbeelding 1 van 2 Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 2, afbeelding 2 van 2
    • Carefully pry the plastic pieces apart, working your way around the ear cushion.
    • Be sure not to break the tabs on the back side of the ear pad!
  3. Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 3, afbeelding 1 van 3 Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 3, afbeelding 2 van 3 Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 3, afbeelding 3 van 3
    • Pull the loosened ear pad apart from the rest of the speaker.
    • Pushing the pad and the speaker back together is the only step required for ear pad reassembly.
  4. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: stap 4, afbeelding 1 van 2 Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: stap 4, afbeelding 2 van 2
    • Remove four 7.3mm PH0 screws.
    • As these screws are very small, it may be best to keep them in a plastic bag or other container.
  5. Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 5, afbeelding 1 van 2 Turtle Beach Ear Force XO Four Speaker Cone Replacement: stap 5, afbeelding 2 van 2
    • Lift speaker cone off of the back casing.
    • Be gentle; the small wires connecting the speaker cone to the rest of the device may break if you pull too hard.
    • Follow iFixit's soldering guide to remove the wires connected to the speaker.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Evalyn Johnson
228 Reputatie
2 handleidingen geschreven
Baylor, Team 10-14, Williams Fall 2015 Lid van Baylor, Team 10-14, Williams Fall 2015
BU-WILLIAMS-F15S10G14
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 9,409
