Inleiding
This guide will show you step-by-step how to replace the speakers in your Trio Stealth-G4X tablet. Speakers may become damaged by regular usage over a long period of time or from constant high volume. Before starting the repair, make sure your problem is not related to a software issue. A quick way to see if your speakers are damaged and need replaced is to turn up the volume on the device and check to see if the sound if muffled or rattling, or if there is no sound at all.
Wat je nodig hebt
Starting near the middle edge of the Trio Stealth-G4X tablet, gently work the small pry tool in between the seams of one side of the tablet.
Look closely at the soldering points. Take note of how the positive(Red) and negative(Black) connections are placed on the motherboard. With your soldering iron carefully heat the solder point until it begins to melt. Once molten, gently pull the wire off of the connection point. De-solder both positive and negative wires for each problem speaker.
Re-soldering is the same process as de-soldering, except you will also add solder. Be sure to be precise and clean when soldering. Look up soldering tutorials for help on youtube if you do not feel comfortable. Once all wires are re-soldered reassemble the tablet following the steps in reverse order.
