Ga door naar hoofdinhoud
Trio Stealth-G4X Screen Replacement
Wat je nodig hebt
  1. Trio Stealth-G4X Screen Replacement, Camera: stap 1, afbeelding 1 van 1
    • Starting near the middle edge of the Trio Stealth-G4X tablet, gently work an opening pick or spudger in between the seams of one side of the tablet.
  2. Trio Stealth-G4X Screen Replacement: stap 2, afbeelding 1 van 1
    • Work your way around all four corners of the tablet, unlocking all of the retaining tabs that hold the tablet together. This will allow you to separate the two halves of the tablet and access the motherboard.
    • Be sure not to over penetrate while separating the two halves as you may damage the tablet's internal hardware.
  3. Trio Stealth-G4X Screen Replacement: stap 3, afbeelding 1 van 1
    • Once the two halves are separated, set aside the back cover of the tablet as you will not need it until reassembly. Now locate the camera on the motherboard of the tablet.
  4. Trio Stealth-G4X Screen Replacement: stap 4, afbeelding 1 van 1
    • Peel back the yellow protective film on the motherboard to access the camera's ribbon cable.
  5. Trio Stealth-G4X Screen Replacement: stap 5, afbeelding 1 van 1
    • Take the Phillips head screwdriver and unscrew the 3mm screw right above the camera assembly. Place the screw aside so you do not lose it.
  6. Trio Stealth-G4X Screen Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to pry the black tab on this connection point upwards. This will unlock the ribbon cable that connects the camera to the motherboard.
    • Once unlocked, very carefully pull the cable out of the socket to disconnect it.
    • Be very delicate with the ribbon cable because it can tear easily.
  7. Trio Stealth-G4X Screen Replacement: stap 7, afbeelding 1 van 1
    • Now you can remove the camera assembly. Use a spudger to gently loosen the camera out of place.
  8. Trio Stealth-G4X Screen Replacement: stap 8, afbeelding 1 van 1
    • Grab the camera assembly with your fingers and gently lift it out of the tablet.
  9. Trio Stealth-G4X Screen Replacement: stap 9, afbeelding 1 van 1
    • You have now removed the camera assembly and can set it aside. Insert replacement camera by following the steps in reverse. Then reassemble the tablet the same way.
  10. Trio Stealth-G4X Screen Replacement, Screen: stap 10, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement, Screen: stap 10, afbeelding 2 van 2
    • Slowly remove the yellow film covering the motherboard.
  11. Trio Stealth-G4X Screen Replacement: stap 11, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the three remaining 3 mm screws from the motherboard using a Phillips screwdriver.
  12. Trio Stealth-G4X Screen Replacement: stap 12, afbeelding 1 van 1
    • Locate the green wiring band at the bottom of the battery.
    • Although it has soldering points, you will not need to desolder the band for this replacement.
    • Very carefully use a spudger to peel the wiring band off of the battery pack.
  13. Trio Stealth-G4X Screen Replacement: stap 13, afbeelding 1 van 1
    • Find the ribbon cable in the top right corner of the tablet.
    • This connects the digitizer to the motherboard.
    • Use a spudger to pry the black tab upwards, unlocking the ribbon cable connector.
  14. Trio Stealth-G4X Screen Replacement: stap 14, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 14, afbeelding 2 van 2
    • Use a spudger to lift the right side of the ribbon cable and disconnect it from the motherboard.
  15. Trio Stealth-G4X Screen Replacement: stap 15, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 15, afbeelding 2 van 2
    • Find the second ribbon cable near the top left corner of the tablet.
    • This connects the LCD screen display to the motherboard.
    • Use a spudger to pry the black tab upwards, disconnecting the ribbon cable.
  16. Trio Stealth-G4X Screen Replacement: stap 16, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 16, afbeelding 2 van 2
    • Locate the microphone in the top left corner of the tablet. This piece easily pops our of the hole it is sitting in with the help of a spudger.
  17. Trio Stealth-G4X Screen Replacement: stap 17, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 17, afbeelding 2 van 2
    • After all of these steps, the motherboard, speakers, and battery should all be able to be removed as one piece. The battery may have adhesive retaining it. To remove it work a pry tool underneath carefully separating it from the back of LCD screen.
    • Be careful when lifting all of these components out of the tablet.
  18. Trio Stealth-G4X Screen Replacement: stap 18, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 18, afbeelding 2 van 2
    • Next, gently work a spudger in between the screen and tablet in the top left corner. This starts to separate the adhesive holding the screen and tablet together.
    • Work your way down the left side of the tablet.
  19. Trio Stealth-G4X Screen Replacement: stap 19, afbeelding 1 van 2 Trio Stealth-G4X Screen Replacement: stap 19, afbeelding 2 van 2
    • Start in the top right corner of the tablet and use a spudger to work your way down the right side, further separating the screen and the tablet.
  20. Trio Stealth-G4X Screen Replacement: stap 20, afbeelding 1 van 1
    • The screen should now be able to be removed from the tablet.
    • Be sure to clean off any leftover adhesive from the tablet before installing the new screen. Re-installation and assembly can be done by following these steps in reverse order.
Conclusie
Emily Dorsey
434 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 804
