Inleiding
This guide will demonstrate how to replace the camera in a Trio Stealth-G4X tablet. You may be experiencing malfunctions with your camera such as blurry pictures, a broken lens, the camera not taking pictures, etc. These problems may be caused by a damaged camera that needs to be replaced. However, make sure that the camera is damaged and you are not experiencing a software issue before attempting this replacement. You can check the troubleshooting page to see if your problem requires camera replacement or if it can be fixed otherwise.
Wat je nodig hebt
Starting near the middle edge of the Trio Stealth-G4X tablet, gently work an opening pick or spudger in between the seams of one side of the tablet.
