Ga door naar hoofdinhoud
Trio Stealth G4 Speaker Replacement
Wat je nodig hebt
  1. Trio Stealth G4 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
  2. Trio Stealth G4 Speaker Replacement: stap 2, afbeelding 1 van 2 Trio Stealth G4 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
  3. Trio Stealth G4 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
  4. Trio Stealth G4 Speaker Replacement: stap 4, afbeelding 1 van 2 Trio Stealth G4 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the back panel from the rest of the tablet and set it aside.
  5. Trio Stealth G4 Speaker Replacement: stap 5, afbeelding 1 van 1
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
  6. Trio Stealth G4 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Trio Stealth G4 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Remove the yellow tape covering the set of wires located near the upper right corner of the battery.
  7. Trio Stealth G4 Speaker Replacement: stap 7, afbeelding 1 van 2 Trio Stealth G4 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use the soldering iron to melt away the solder from the red and black wires that connect the speaker to the motherboard.
    • Once the solder is completely removed, pull the wires away from the motherboard.
  8. Trio Stealth G4 Speaker Replacement: stap 8, afbeelding 1 van 2 Trio Stealth G4 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Use a J000 Phillips head screwdriver to remove the two 4.3 mm screws securing the speaker to the device and set them aside.
  9. Trio Stealth G4 Speaker Replacement: stap 9, afbeelding 1 van 3 Trio Stealth G4 Speaker Replacement: stap 9, afbeelding 2 van 3 Trio Stealth G4 Speaker Replacement: stap 9, afbeelding 3 van 3
    • Use your fingers to remove the plastic L-shaped speaker housing from the tablet.
Conclusie
Matt Arnold
607 Reputatie
5 handleidingen geschreven
Baylor, Team 4-1, Williams Fall 2015 Lid van Baylor, Team 4-1, Williams Fall 2015
BU-WILLIAMS-F15S4G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 260
