Ga door naar hoofdinhoud
Trio STEALTH-9 Motherboard Replacement
Wat je nodig hebt
  1. Trio STEALTH-9 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the two Phillips #00 screws on the side of the tablet.
    Vraag FixBot
    Voeg opmerking toe
  2. Trio STEALTH-9 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
    Vraag FixBot
    Voeg opmerking toe
  3. Trio STEALTH-9 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
    Vraag FixBot
    Voeg opmerking toe
  4. Trio STEALTH-9 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
    Vraag FixBot
    Voeg opmerking toe
  5. Trio STEALTH-9 Motherboard Replacement, Battery: stap 5, afbeelding 1 van 1
    • With the cover removed, slowly pull the electrical tape away as shown.
    Vraag FixBot
    Voeg opmerking toe
  6. Trio STEALTH-9 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Slowly pull the Battery away from the tablet frame.
    Vraag FixBot
    Voeg opmerking toe
  7. Trio STEALTH-9 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Prepare your Soldering Iron and Removal Tools.
    • Contact the iron with each of the battery leads, and pull the lead away from the board.
    • Remove any excess solder as needed.
    Vraag FixBot
    Voeg opmerking toe
  8. Trio STEALTH-9 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
    • Apply heat and solder to each lead individually.
    • Remove any excess solder if flooding occurs.
    Vraag FixBot
    Voeg opmerking toe
  9. Trio STEALTH-9 Motherboard Replacement, Camera: stap 9, afbeelding 1 van 2 Trio STEALTH-9 Motherboard Replacement, Camera: stap 9, afbeelding 2 van 2
    • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  10. Trio STEALTH-9 Motherboard Replacement: stap 10, afbeelding 1 van 2 Trio STEALTH-9 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
    Vraag FixBot
    Voeg opmerking toe
  11. Trio STEALTH-9 Motherboard Replacement: stap 11, afbeelding 1 van 2 Trio STEALTH-9 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
    • Remove the camera from the frame and replace as needed.
    Vraag FixBot
    Voeg opmerking toe
  12. Trio STEALTH-9 Motherboard Replacement, Speaker: stap 12, afbeelding 1 van 1
    • Slowly remove the electrical tape holding down the Speaker wires.
    Vraag FixBot
    Voeg opmerking toe
  13. Trio STEALTH-9 Motherboard Replacement: stap 13, afbeelding 1 van 2 Trio STEALTH-9 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
    Vraag FixBot
    Voeg opmerking toe
  14. Trio STEALTH-9 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
    • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
    Vraag FixBot
    Voeg opmerking toe
  15. Trio STEALTH-9 Motherboard Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
    Vraag FixBot
    Voeg opmerking toe
  16. Trio STEALTH-9 Motherboard Replacement: stap 16, afbeelding 1 van 3 Trio STEALTH-9 Motherboard Replacement: stap 16, afbeelding 2 van 3 Trio STEALTH-9 Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Remove the three #00 Screws holding down the Motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. Trio STEALTH-9 Motherboard Replacement: stap 17, afbeelding 1 van 2 Trio STEALTH-9 Motherboard Replacement: stap 17, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of Tweezers to carefully pull the side buttons away from the frame.
    • Use the same Tweezers to carefully pull the microphone away from the front of the frame.
    Vraag FixBot
    Voeg opmerking toe
  18. Trio STEALTH-9 Motherboard Replacement: stap 18, afbeelding 1 van 3 Trio STEALTH-9 Motherboard Replacement: stap 18, afbeelding 2 van 3 Trio STEALTH-9 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
    Vraag FixBot
    Voeg opmerking toe
  19. Trio STEALTH-9 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • With the cables removed, lift the Motherboard off of the frame.
    • Repair or replace the Motherboard as needed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
Mei Liang
228 Reputatie
2 handleidingen geschreven
Clemson, Team 15-5, Shirley Winter 2015 Lid van Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 985
