Ga door naar hoofdinhoud
Trio STEALTH-9 Back Cover Replacement
Wat je nodig hebt
    1. Trio STEALTH-9 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Remove the two Phillips #00 screws on the side of the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. Trio STEALTH-9 Back Cover Replacement: stap 2, afbeelding 1 van 1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. Trio STEALTH-9 Back Cover Replacement: stap 3, afbeelding 1 van 1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      Vraag FixBot
      Voeg opmerking toe
    4. Trio STEALTH-9 Back Cover Replacement: stap 4, afbeelding 1 van 1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order with your replacement cover!
Mei Liang
228 Reputatie
2 handleidingen geschreven
Clemson, Team 15-5, Shirley Winter 2015 Lid van Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Leden
4 handleidingen geschreven
2Gids Commentaar
Tengo.una y costo tiene el.displey
eliehtmaria - Antwoord Deel
Deseo.saber el.c
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 1,548
