Ga door naar hoofdinhoud
Trio AXS 3G Camera Replacement
Wat je nodig hebt
    1. Trio AXS 3G Camera Replacement, Back Case: stap 1, afbeelding 1 van 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Vraag FixBot
      Voeg opmerking toe
    2. Trio AXS 3G Camera Replacement: stap 2, afbeelding 1 van 2 Trio AXS 3G Camera Replacement: stap 2, afbeelding 2 van 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Vraag FixBot
      Voeg opmerking toe
    3. Trio AXS 3G Camera Replacement: stap 3, afbeelding 1 van 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Trio AXS 3G Camera Replacement, Camera: stap 4, afbeelding 1 van 2 Trio AXS 3G Camera Replacement, Camera: stap 4, afbeelding 2 van 2
      • Unscrew 5 #000 4 mm and 3 mm screws around the strip.
      Vraag FixBot
      Voeg opmerking toe
    2. Trio AXS 3G Camera Replacement: stap 5, afbeelding 1 van 1
      • Undo the tape on top of the connector from the camera to motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Trio AXS 3G Camera Replacement: stap 6, afbeelding 1 van 1
      • Slightly lift up the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Trio AXS 3G Camera Replacement: stap 7, afbeelding 1 van 2 Trio AXS 3G Camera Replacement: stap 7, afbeelding 2 van 2
      • Disconnect the camera from the motherboard on the topside and pull the camera strip out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Javoy Ross
316 Reputatie
3 handleidingen geschreven
1Gids Commentaar
Where can I get the camera?
Amanda Springsteen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 448
