Ga door naar hoofdinhoud
Trio AXS 3G Battery Replacement
Wat je nodig hebt
    1. Trio AXS 3G Battery Replacement, Back Case: stap 1, afbeelding 1 van 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Vraag FixBot
      Voeg opmerking toe
    2. Trio AXS 3G Battery Replacement: stap 2, afbeelding 1 van 2 Trio AXS 3G Battery Replacement: stap 2, afbeelding 2 van 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Vraag FixBot
      Voeg opmerking toe
    3. Trio AXS 3G Battery Replacement: stap 3, afbeelding 1 van 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Trio AXS 3G Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
      Vraag FixBot
      Voeg opmerking toe
    2. Trio AXS 3G Battery Replacement: stap 5, afbeelding 1 van 1
      • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Trio AXS 3G Battery Replacement: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
      Vraag FixBot
      Voeg opmerking toe
    4. Trio AXS 3G Battery Replacement: stap 7, afbeelding 1 van 1
      • Peel off the battery from the device to completely remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
2Gids Commentaar
where can i buy a battery replacement? can it work without a battery?
millie abanilla - Antwoord Deel
where can you buy a replacement battery
J W - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 1,652
