Ga door naar hoofdinhoud
Triggers Removal
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Triggers Removal, Prepare your device for disassembly: stap 1, afbeelding 1 van 3 Triggers Removal, Prepare your device for disassembly: stap 1, afbeelding 2 van 3 Triggers Removal, Prepare your device for disassembly: stap 1, afbeelding 3 van 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Triggers Removal, Unfasten the back cover: stap 2, afbeelding 1 van 2 Triggers Removal, Unfasten the back cover: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Triggers Removal, Insert an opening pick: stap 3, afbeelding 1 van 3 Triggers Removal, Insert an opening pick: stap 3, afbeelding 2 van 3 Triggers Removal, Insert an opening pick: stap 3, afbeelding 3 van 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Triggers Removal, Release the back cover's clips: stap 4, afbeelding 1 van 3 Triggers Removal, Release the back cover's clips: stap 4, afbeelding 2 van 3 Triggers Removal, Release the back cover's clips: stap 4, afbeelding 3 van 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Triggers Removal, Remove the back cover: stap 5, afbeelding 1 van 3 Triggers Removal, Remove the back cover: stap 5, afbeelding 2 van 3 Triggers Removal, Remove the back cover: stap 5, afbeelding 3 van 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Triggers Removal, Unfasten the triggers: stap 6, afbeelding 1 van 3 Triggers Removal, Unfasten the triggers: stap 6, afbeelding 2 van 3 Triggers Removal, Unfasten the triggers: stap 6, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing each trigger (four screws total).
  7. Triggers Removal, Remove the triggers: stap 7, afbeelding 1 van 3 Triggers Removal, Remove the triggers: stap 7, afbeelding 2 van 3 Triggers Removal, Remove the triggers: stap 7, afbeelding 3 van 3
    • Pull the triggers straight up and out of their recesses to remove them.
  8. Triggers Removal, Trigger installation: stap 8, afbeelding 1 van 1
    • During reassembly:
    • Compress the trigger and firmly push it into place on the chassis so the cutouts on the hinge go over their alignment posts. The trigger should stay in place.
    • Keep the trigger compressed and install the two screws.
    • Test the trigger before continuing reassembly. If it's not working properly, remove the trigger and make sure it's properly aligned on the hinge.
Conclusie
Spencer Day
164.244 Reputatie
1.043 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.258 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 98
