Ga door naar hoofdinhoud
TotalPond Pond Pump Impeller Replacement
    1. TotalPond Pond Pump Impeller Replacement, Impeller: stap 1, afbeelding 1 van 1
      • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
      Vraag FixBot
      Voeg opmerking toe
    2. TotalPond Pond Pump Impeller Replacement: stap 2, afbeelding 1 van 1
      • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
      Vraag FixBot
      Voeg opmerking toe
    3. TotalPond Pond Pump Impeller Replacement: stap 3, afbeelding 1 van 2 TotalPond Pond Pump Impeller Replacement: stap 3, afbeelding 2 van 2
      • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
      Vraag FixBot
      Voeg opmerking toe
    4. TotalPond Pond Pump Impeller Replacement: stap 4, afbeelding 1 van 2 TotalPond Pond Pump Impeller Replacement: stap 4, afbeelding 2 van 2
      • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nicole Santana
612 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-6, Hickman Winter 2015 Lid van USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 46
Altijd: 3,788
