Ga door naar hoofdinhoud
Toshiba Satellite U840W 12V Charging Port Replacement
Wat je nodig hebt
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: stap 1, afbeelding 1 van 2 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: stap 1, afbeelding 2 van 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite U840W 12V Charging Port Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite U840W 12V Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite U840W 12V Charging Port Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite U840W 12V Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: stap 6, afbeelding 1 van 1
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Remove the 12v charging port from the cover.
Conclusie
Joshua Pedersen
217 Reputatie
1 Handleiding geschreven
Gateway, Team S1-G1, Saknee Spring 2019 Lid van Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 241
