Ga door naar hoofdinhoud
Toshiba Encore Mini Front-Facing Camera Replacement
Wat je nodig hebt
  1. Toshiba Encore Mini Front-Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
    Vraag FixBot
    Voeg opmerking toe
  2. Toshiba Encore Mini Front-Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the rear cover and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  3. Toshiba Encore Mini Front-Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the electrical tape that holds the battery in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Toshiba Encore Mini Front-Facing Camera Replacement: stap 4, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
    Vraag FixBot
    Voeg opmerking toe
  5. Toshiba Encore Mini Front-Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
    Vraag FixBot
    Voeg opmerking toe
  6. Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 1 van 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 2 van 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 3 van 3
    • The audio module must be removed to replace the front-facing camera.
    • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
    • Gently remove red/black wire strands from the clips holding them to the back of the screen.
    Vraag FixBot
    Voeg opmerking toe
  7. Toshiba Encore Mini Front-Facing Camera Replacement: stap 7, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
    • Adhesive on the bottom of the speaker module may make it difficult to remove.
    • Set the audio module and attached wire aside.
    Vraag FixBot
    Voeg opmerking toe
  8. Toshiba Encore Mini Front-Facing Camera Replacement: stap 8, afbeelding 1 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 8, afbeelding 2 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 8, afbeelding 3 van 3
    • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
    • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
    Vraag FixBot
    Voeg opmerking toe
  9. Toshiba Encore Mini Front-Facing Camera Replacement: stap 9, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement: stap 9, afbeelding 2 van 2
    • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
    • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
    Vraag FixBot
    Voeg opmerking toe
  10. Toshiba Encore Mini Front-Facing Camera Replacement: stap 10, afbeelding 1 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 10, afbeelding 2 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 10, afbeelding 3 van 3
    • Damaging this ribbon will permanently disable your device!
    • Using needle-nose tweezers, carefully flip up the dark gray cover.
    • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
    Vraag FixBot
    Voeg opmerking toe
  11. Toshiba Encore Mini Front-Facing Camera Replacement: stap 11, afbeelding 1 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 11, afbeelding 2 van 3 Toshiba Encore Mini Front-Facing Camera Replacement: stap 11, afbeelding 3 van 3
    • Using a Phillips 000 screwdriver, remove the screws holding components together.
    • Remove four 4.2 mm Phillips screws.
    • Remove one 3mm Phillips screw.
    Vraag FixBot
    Voeg opmerking toe
  12. Toshiba Encore Mini Front-Facing Camera Replacement: stap 12, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement: stap 12, afbeelding 2 van 2
    • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
    • The motherboard may resist as you try to lift it --this is normal.
    Vraag FixBot
    Voeg opmerking toe
  13. Toshiba Encore Mini Front-Facing Camera Replacement: stap 13, afbeelding 1 van 2 Toshiba Encore Mini Front-Facing Camera Replacement: stap 13, afbeelding 2 van 2
    • The front-facing camera may dislodge freely when removing the motherboard.
    • If camera has not already "popped" off the motherboard, use needle-nose tweezers to gently grasp the camera and remove from motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Shirley Low
143 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-3, Liner SU 2015 Lid van UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 699
