Ga door naar hoofdinhoud
Toshiba Chromebook 2 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Chromebook 2 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: stap 4, afbeelding 1 van 2 Toshiba Chromebook 2 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Toshiba Chromebook 2 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: stap 8, afbeelding 1 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 8, afbeelding 2 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: stap 9, afbeelding 1 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 9, afbeelding 2 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: stap 10, afbeelding 1 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 10, afbeelding 2 van 3 Toshiba Chromebook 2 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: stap 11, afbeelding 1 van 2 Toshiba Chromebook 2 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
Conclusie
Sam Nishi
485 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-4, Livingston Fall 2016 Lid van Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 2,868
