Inleiding
This guide requires soldering, a guide for which can be found here.
Wat je nodig hebt
From the top view, remove each of the four pins that hold the casing in place.
Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
Remove the shell of the truck. Using a Phillips #1 screwdriver, remove the seven 10mm screws highlighted.
Bijna klaar!
Conclusie
