Ga door naar hoofdinhoud
TomTom One XL Screen Replacement
Wat je nodig hebt
    1. TomTom One XL Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 TomTom One XL Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
      • Remove the 4 .4mm screws on the back of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. TomTom One XL Screen Replacement: stap 2, afbeelding 1 van 1
      • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
      • You can rotate TOMTOM XL to make prying back off easier.
      • Be careful not to injure the two wires connecting the pieces.
      Vraag FixBot
      Voeg opmerking toe
    3. TomTom One XL Screen Replacement: stap 3, afbeelding 1 van 1
      • After prying both halves apart, they will be connected by two wires.
      • Carefully set the two halves next to each other making sure not to stress or damage the wires.
      Vraag FixBot
      Voeg opmerking toe
    4. TomTom One XL Screen Replacement: stap 4, afbeelding 1 van 2 TomTom One XL Screen Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
      • Be gentle while pulling the wires out, the plugs are easily injured.
      Vraag FixBot
      Voeg opmerking toe
    1. TomTom One XL Screen Replacement, Screen: stap 5, afbeelding 1 van 2 TomTom One XL Screen Replacement, Screen: stap 5, afbeelding 2 van 2
      • Locate the 4 .4mm screws connecting the circuit board to the front panel.
      • Use the T6 Torx screwdriver and remove the four screws.
      Vraag FixBot
      Voeg opmerking toe
    2. TomTom One XL Screen Replacement: stap 6, afbeelding 1 van 3 TomTom One XL Screen Replacement: stap 6, afbeelding 2 van 3 TomTom One XL Screen Replacement: stap 6, afbeelding 3 van 3
      • Locate the ribbon cable connecting the front panel to the circuit board.
      • Locate the white tab locking the ribbon in place.
      • Using precision tweezers push the left and right side of the tab forward.
      • Gently pull the ribbon to disconnect the circuit board from the front panel.
      • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
      Vraag FixBot
      Voeg opmerking toe
    3. TomTom One XL Screen Replacement: stap 7, afbeelding 1 van 3 TomTom One XL Screen Replacement: stap 7, afbeelding 2 van 3 TomTom One XL Screen Replacement: stap 7, afbeelding 3 van 3
      • Use the palate knife to pry the screen away from the front panel.
      • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
      • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
DeVhan
401 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 43
Altijd: 1,283
