Inleiding
The battery is underneath the motherboard so power off the device before starting the disassembly.
Wat je nodig hebt
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
After opening the device and removing the motherboard, you will see the battery attached to the frame.
22 andere personen hebben deze handleiding voltooid.
7Gids Commentaar
Very effective guide, easy to follow and good images too, thank you Mike
Most difficult part was opening the case, seemed to work best with the opening tool ends pointed down (screen up), levered the latches best.
Reassembling, the larger of the two connections that attach the screen to the motherboard case was fiddly to line up, it requires a bit of care and patience.
Thanks for these instructions.
Thanks, Oriana Hone (and 3 other contributors), good guide. Used it for GO 5000.
And yes, as forewarned, 4 of the plastic latches broke easily during the opening process. Now I guess I'll have to find a new screen casing... Or will the remaining suffice?
