Ga door naar hoofdinhoud
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
Wat je nodig hebt
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: stap 1, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: stap 1, afbeelding 2 van 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: stap 2, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: stap 2, afbeelding 2 van 2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: stap 3, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: stap 3, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: stap 3, afbeelding 3 van 3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: stap 4, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: stap 4, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: stap 4, afbeelding 3 van 3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: stap 5, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: stap 5, afbeelding 2 van 2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: stap 6, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: stap 6, afbeelding 2 van 2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: stap 7, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: stap 7, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: stap 7, afbeelding 3 van 3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: stap 8, afbeelding 1 van 1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: stap 9, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: stap 9, afbeelding 2 van 2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: stap 10, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: stap 10, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: stap 10, afbeelding 3 van 3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Diaz-Kokaisl
125.025 Reputatie
582 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 296
