Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je Thomas Ride On Train te repareren, gebruik onze reparatiehandleidingen.
    1. Thomas Ride on Train - System Diagram and Components, Thomas Ride on Train - System Diagram and Components: stap 1, afbeelding 1 van 1
      • System Components
      • When power is applied to the charging connector it activates a relay which disconnects the power to the main circuits.
      • The main powerswitch is under the large yellow lever and simply applies power from the battery to the control board in the console.
      • A multipole switch is used to reverse the direction of the motor
      • An LED in the console flashes with the sound
      • The sound is provided by a loudspeaker in the base
      Vraag FixBot
      Voeg opmerking toe
    2. Thomas Ride on Train - System Diagram and Components: stap 2, afbeelding 1 van 2 Thomas Ride on Train - System Diagram and Components: stap 2, afbeelding 2 van 2
      • Charging Connector
      • The charging connector is on the rear of the train between the buffers
      • My connector is a "old style" connector which is effectively a phono, the new style is a more conventional power connector
      Vraag FixBot
      Voeg opmerking toe
    3. Thomas Ride on Train - System Diagram and Components: stap 3, afbeelding 1 van 1
      • Power Switch and Charging Relay Board
      Vraag FixBot
      Voeg opmerking toe
    4. Thomas Ride on Train - System Diagram and Components, 6v Sealed Lead Acid Battery: stap 4, afbeelding 1 van 1
      • This battery has been replaced, the originals attach via a clip
      • Note the fuse on the positive connector
      Vraag FixBot
      Voeg opmerking toe
    5. Thomas Ride on Train - System Diagram and Components, Reversing switch and LED: stap 5, afbeelding 1 van 1
      • This switch is controlled by the level on the console and switches the polarity of the motor connectors.
      • Middle position is off, the other two positions are forward and backwards
      • If you are replacing the LED don't forget that the polarity of the wires is important
      Vraag FixBot
      Voeg opmerking toe
    6. Thomas Ride on Train - System Diagram and Components, Control board: stap 6, afbeelding 1 van 1
      • Has three switches to activate the music and connectors leading off to the motor, speaker, LED and battery
      Vraag FixBot
      Voeg opmerking toe
    7. Thomas Ride on Train - System Diagram and Components, Loudspeaker: stap 7, afbeelding 1 van 1
      • This is a 16ohm speaker
      Vraag FixBot
      Voeg opmerking toe
    8. Thomas Ride on Train - System Diagram and Components, Motor: stap 8, afbeelding 1 van 1
      • 6v electric motor with capacitor for noise and spark suppressor wired across the terminals
      Vraag FixBot
      Voeg opmerking toe
Andy from Workshopshed
447 Reputatie
3 handleidingen geschreven
10Gids Commentaar
sound their but it's stoped moving
Leona - Antwoord Deel
If you've got sound but no movement then the most likely cause is the battery is discharged or defective. If you have a multimeter you could check the voltage on the battery.
If may also be a motor / mechanical issue. With the power disconnected you should be able to rotate the wheels but it won't spin freely as there is a gearbox.
Andy from Workshopshed - Antwoord Deel
Movement but no sound? Been charged
Shiipwreck Flynn - Antwoord Deel
That could be a problem with the sound board which lives inside the steering wheel. It's quite a challenge to get to that which is what caused me to write the guide in the first place. I had to clean the switches on that board to get mine to work.
Alternatively could be a loose or broken wire on the speaker which is down in the base, one of the first things you get too when stripping it down.
What do I clean it with? Just polish? Had a look. Wires look fine so im confused lol
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 77
Altijd: 9,069
