Ga door naar hoofdinhoud
ThinkPad Edge E31 Wireless Card Replacement
Wat je nodig hebt
  1. ThinkPad Edge E31 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Vraag FixBot
    Voeg opmerking toe
  2. ThinkPad Edge E31 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. ThinkPad Edge E31 Wireless Card Replacement, ThinkPad Edge E31 Underside Disassembly: stap 3, afbeelding 1 van 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Vraag FixBot
    Voeg opmerking toe
  4. ThinkPad Edge E31 Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • The wireless card is located above the Hard drive and RAM on the exposed laptop.
    • There are 2, 4mm long M2 screws holding the wireless card to the laptop. Unscrew the screws.
    Vraag FixBot
    Voeg opmerking toe
  5. ThinkPad Edge E31 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Once the screws are removed, there will be 2 wires attached to the card. These can be easily popped off by hand to fully disconnect the card form the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Riley
601 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 367
