Ga door naar hoofdinhoud
The Sharper Image Literati Tablet Screen Replacement
Wat je nodig hebt
  1. The Sharper Image Literati Tablet Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Screen Replacement: stap 2, afbeelding 1 van 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Screen Replacement: stap 3, afbeelding 1 van 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Screen Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet Screen Replacement, SD Port: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet Screen Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet Screen Replacement: stap 8, afbeelding 1 van 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet Screen Replacement: stap 9, afbeelding 1 van 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet Screen Replacement: stap 12, afbeelding 1 van 1
    • Remove the silver backing plate and the adhered SD port chip.
  13. The Sharper Image Literati Tablet Screen Replacement, Screen: stap 13, afbeelding 1 van 3 The Sharper Image Literati Tablet Screen Replacement, Screen: stap 13, afbeelding 2 van 3 The Sharper Image Literati Tablet Screen Replacement, Screen: stap 13, afbeelding 3 van 3
    • Unravel the screen from the silver backing.
  14. The Sharper Image Literati Tablet Screen Replacement: stap 14, afbeelding 1 van 1
    • Unclip JIF clip and remove ribbin cable.
Conclusie
Spencer Dodder
560 Reputatie
4 handleidingen geschreven
IUPUI, Team S5-G4, Baechle Spring 2018 Lid van IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 369
