Ga door naar hoofdinhoud
The Sharper Image Literati Tablet Battery Replacement
Wat je nodig hebt
  1. The Sharper Image Literati Tablet Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Battery Replacement: stap 2, afbeelding 1 van 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Battery Replacement: stap 3, afbeelding 1 van 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Battery Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Spencer Dodder
560 Reputatie
4 handleidingen geschreven
IUPUI, Team S5-G4, Baechle Spring 2018 Lid van IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,036
