Ga door naar hoofdinhoud
The Claw Case Replacement
Wat je nodig hebt
    1. The Claw Case Replacement, Top Cover: stap 1, afbeelding 1 van 1
      • Place The Claw machine in the up-right position with the control knobs facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. The Claw Case Replacement: stap 2, afbeelding 1 van 1
      • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
      Vraag FixBot
      Voeg opmerking toe
    3. The Claw Case Replacement: stap 3, afbeelding 1 van 1
      • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
      • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
      Vraag FixBot
      Voeg opmerking toe
    4. The Claw Case Replacement: stap 4, afbeelding 1 van 1
      • Turn The Claw machine back to the upright position with controls facing you.
      Vraag FixBot
      Voeg opmerking toe
    5. The Claw Case Replacement: stap 5, afbeelding 1 van 1
      • Remove the top cover of The Claw machine.
      Vraag FixBot
      Voeg opmerking toe
    6. The Claw Case Replacement: stap 6, afbeelding 1 van 2 The Claw Case Replacement: stap 6, afbeelding 2 van 2
      • Remove the ten 6 mm phillips #1 screws from the top flange.
      Vraag FixBot
      Voeg opmerking toe
    7. The Claw Case Replacement: stap 7, afbeelding 1 van 1
      • Lift the flange upward and off to the side of the machine.
      • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
      • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
      Vraag FixBot
      Voeg opmerking toe
    1. The Claw Case Replacement, Case: stap 8, afbeelding 1 van 1
      • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
      Vraag FixBot
      Voeg opmerking toe
    2. The Claw Case Replacement: stap 9, afbeelding 1 van 1
      • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
      Vraag FixBot
      Voeg opmerking toe
    3. The Claw Case Replacement: stap 10, afbeelding 1 van 1
      • Gently remove the broken clear plastic case.
      • Remember how the case sat into the frame so that you can seat the new case in the same way.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alain Pierre
1.188 Reputatie
9 handleidingen geschreven
UMass Dartmouth, Team 4-8, Catania Spring 2016 Lid van UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
3 Leden
18 handleidingen geschreven
1Gids Commentaar
where can i get the clear plastic panels
cristian2002 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 47
Altijd: 2,113
