Ga door naar hoofdinhoud
Texas Instruments TI-92 Batteries Replacement
Wat je nodig hebt
    1. Texas Instruments TI-92 Batteries Replacement, Back Cover: stap 1, afbeelding 1 van 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: stap 1, afbeelding 2 van 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-92 Batteries Replacement: stap 2, afbeelding 1 van 2 Texas Instruments TI-92 Batteries Replacement: stap 2, afbeelding 2 van 2
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-92 Batteries Replacement: stap 3, afbeelding 1 van 2 Texas Instruments TI-92 Batteries Replacement: stap 3, afbeelding 2 van 2
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      Vraag FixBot
      Voeg opmerking toe
    1. Texas Instruments TI-92 Batteries Replacement, Batteries: stap 4, afbeelding 1 van 3 Texas Instruments TI-92 Batteries Replacement, Batteries: stap 4, afbeelding 2 van 3 Texas Instruments TI-92 Batteries Replacement, Batteries: stap 4, afbeelding 3 van 3
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Daniel Maldonado
264 Reputatie
9 handleidingen geschreven
Cal Poly, Team 15-51, Garner Spring 2010 Lid van Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Leden
27 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 8,113
