Ga door naar hoofdinhoud
Texas Instruments TI-83 Plus Motherboard & Screen Replacement
Wat je nodig hebt
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: stap 1, afbeelding 1 van 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: stap 1, afbeelding 2 van 2
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 3, afbeelding 1 van 1
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: stap 4, afbeelding 1 van 1
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 5, afbeelding 1 van 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 5, afbeelding 2 van 2
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      Vraag FixBot
      Voeg opmerking toe
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: stap 6, afbeelding 1 van 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: stap 6, afbeelding 2 van 2
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 7, afbeelding 1 van 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: stap 7, afbeelding 2 van 2
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
20 andere personen hebben deze handleiding voltooid.
Kevin
479 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-37, Regan Fall 2012 Lid van Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Leden
23 handleidingen geschreven
16Gids Commentaar
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - Antwoord Deel
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom - Antwoord Deel
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - Antwoord Deel
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 106
Altijd: 51,536
