Ga door naar hoofdinhoud
Texas Instruments TI-83 Plus Backup Battery Replacement
Wat je nodig hebt
    1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: stap 1, afbeelding 1 van 2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: stap 1, afbeelding 2 van 2
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-83 Plus Backup Battery Replacement: stap 2, afbeelding 1 van 1
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-83 Plus Backup Battery Replacement: stap 3, afbeelding 1 van 1
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Clay
38 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-37, Regan Fall 2012 Lid van Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Leden
13 handleidingen geschreven
2Gids Commentaar
Will this wipe the memory?
John Osborne - Antwoord Deel
Yes I found one and have been trying to get it together for a high schooler I had one when I took trig in college and it was very helpful
Jack Irvin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 65
Altijd: 24,088
