Ga door naar hoofdinhoud
Texas Instruments TI-30X IIS Solar Panel Replacement
Wat je nodig hebt
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: stap 1, afbeelding 1 van 2 Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: stap 1, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: stap 2, afbeelding 1 van 1
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: stap 4, afbeelding 1 van 1
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: stap 5, afbeelding 1 van 2 Texas Instruments TI-30X IIS Solar Panel Replacement: stap 5, afbeelding 2 van 2
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 673
