Ga door naar hoofdinhoud
Texas Instruments TI-30X IIS Battery Replacement
Wat je nodig hebt
    1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: stap 1, afbeelding 1 van 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: stap 1, afbeelding 2 van 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: stap 1, afbeelding 3 van 3
      • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
      • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: stap 2, afbeelding 1 van 2 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: stap 2, afbeelding 2 van 2
      • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
      • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: stap 3, afbeelding 1 van 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: stap 3, afbeelding 2 van 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: stap 3, afbeelding 3 van 3
      • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
      • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
      Vraag FixBot
      Voeg opmerking toe
    4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: stap 4, afbeelding 1 van 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: stap 4, afbeelding 2 van 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: stap 4, afbeelding 3 van 3
      • With the rear case off, the battery is exposed and accessible.
      • Using a pointed tool, slide the battery out of its terminal towards the near edge.
      • Once the battery is protruding from the contacts, remove it with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: stap 5, afbeelding 1 van 1
      • Properly dispose of the old battery.
      • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
      • Following the previous steps in the reverse order to reassemble the calculator.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
20 andere personen hebben deze handleiding voltooid.
Ryan
515 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 183
Altijd: 37,613
