Ga door naar hoofdinhoud
Teenage Engineering OP-Z Expansion Module Replacement
  1. Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: stap 1, afbeelding 1 van 3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: stap 1, afbeelding 2 van 3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
    Vraag FixBot
    Voeg opmerking toe
  2. Teenage Engineering OP-Z Expansion Module Replacement: stap 2, afbeelding 1 van 2 Teenage Engineering OP-Z Expansion Module Replacement: stap 2, afbeelding 2 van 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
    Vraag FixBot
    Voeg opmerking toe
  3. Teenage Engineering OP-Z Expansion Module Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom plate including the rubber feet.
    Vraag FixBot
    Voeg opmerking toe
  4. Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: stap 4, afbeelding 1 van 2 Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: stap 4, afbeelding 2 van 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
    Vraag FixBot
    Voeg opmerking toe
  5. Teenage Engineering OP-Z Expansion Module Replacement: stap 5, afbeelding 1 van 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Tobias Isakeit
134.237 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.161 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 1,572
