Ga door naar hoofdinhoud
Teenage Engineering OP-Z Battery Replacement
Wat je nodig hebt
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: stap 2, afbeelding 1 van 2 Teenage Engineering OP-Z Battery Replacement: stap 2, afbeelding 2 van 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Teenage Engineering OP-Z Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: stap 5, afbeelding 1 van 2 Teenage Engineering OP-Z Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
Conclusie
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
119.540 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.093 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 111
Altijd: 7,215
