Ga door naar hoofdinhoud
Teenage Engineering OP-1 Display Replacement
Wat je nodig hebt
  1. Teenage Engineering OP-1 Display Replacement, key removal: stap 1, afbeelding 1 van 3 Teenage Engineering OP-1 Display Replacement, key removal: stap 1, afbeelding 2 van 3 Teenage Engineering OP-1 Display Replacement, key removal: stap 1, afbeelding 3 van 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
    Vraag FixBot
    Voeg opmerking toe
  2. Teenage Engineering OP-1 Display Replacement, removing scissors mechanisms: stap 2, afbeelding 1 van 2 Teenage Engineering OP-1 Display Replacement, removing scissors mechanisms: stap 2, afbeelding 2 van 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
    Vraag FixBot
    Voeg opmerking toe
  3. Teenage Engineering OP-1 Display Replacement, unscrew keyboard: stap 3, afbeelding 1 van 3 Teenage Engineering OP-1 Display Replacement, unscrew keyboard: stap 3, afbeelding 2 van 3 Teenage Engineering OP-1 Display Replacement, unscrew keyboard: stap 3, afbeelding 3 van 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
    Vraag FixBot
    Voeg opmerking toe
  4. Teenage Engineering OP-1 Display Replacement, Display: stap 4, afbeelding 1 van 3 Teenage Engineering OP-1 Display Replacement, Display: stap 4, afbeelding 2 van 3 Teenage Engineering OP-1 Display Replacement, Display: stap 4, afbeelding 3 van 3
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
    • After reassembly you want to perform the three function tests (0, 1 and 2) from the OP-1 special start screen. You can enter this menu by holding the COM key when powering up.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
133.727 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.145 handleidingen geschreven
15Gids Commentaar
It is really helping.
do you know where to get the screen?
thank you.
chefshin - Antwoord Deel
I see that the part # is AMS260CM61 ver 2 by Samsung. However, I have not been able to source it online.
Mike - Antwoord Deel
Hey guys,
Can someone from IFIXIT please let us know where we can buy the screen please.
my screen is cracked and i desperately need to replace it.
Thanks!
Jack - Antwoord Deel
Hi Jack, unfortunately we do not know where to get a replacement screen for the OP-1. You might want to get in contact with the guys from Teenage Engineering directly. Sorry
Tobias Isakeit - Antwoord Deel
Jack, look for “part number 74-x000045”, there are few of them out there. Cheers.
Peter O - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 111
Altijd: 16,634
