Ga door naar hoofdinhoud
Teenage Engineering OP-1 Battery Replacement
Wat je nodig hebt
    1. Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: stap 1, afbeelding 1 van 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: stap 1, afbeelding 2 van 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: stap 1, afbeelding 3 van 3
      • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
      • Lift the back panel and remove it. The Connector Board is revealed.
      • Disconnect the flex connector by lifting it up with a spudger.
      Vraag FixBot
      Voeg opmerking toe
    1. Teenage Engineering OP-1 Battery Replacement, key removal: stap 2, afbeelding 1 van 3 Teenage Engineering OP-1 Battery Replacement, key removal: stap 2, afbeelding 2 van 3 Teenage Engineering OP-1 Battery Replacement, key removal: stap 2, afbeelding 3 van 3
      • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
      • The four longer keys from the fingerboard are to be handled from the left side to get them off.
      • The eight smaller keys need to be levered from the bottom up.
      Vraag FixBot
      Voeg opmerking toe
    2. Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: stap 3, afbeelding 1 van 2 Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: stap 3, afbeelding 2 van 2
      • The scissor mechanism of the eight small keys are obstructing the underlying screws.
      • By using again an opening tool or opening pick these can be snapped off easily.
      • When reassembling be sure to place them in with the correct side facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    3. Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: stap 4, afbeelding 1 van 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: stap 4, afbeelding 2 van 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: stap 4, afbeelding 3 van 3
      • Loosen those 12 screws with a Phillips #00 screwdriver.
      • Then just pull off the four rotary knobs and the volume knob.
      • Now it is possible to slightly lift the keyboard and set it back.
      Vraag FixBot
      Voeg opmerking toe
    1. Teenage Engineering OP-1 Battery Replacement, battery removal: stap 5, afbeelding 1 van 3 Teenage Engineering OP-1 Battery Replacement, battery removal: stap 5, afbeelding 2 van 3 Teenage Engineering OP-1 Battery Replacement, battery removal: stap 5, afbeelding 3 van 3
      • Carefully pull out the connector cable from the connector board and bend it out of the way.
      • Disconnect the battery with a spudger. The connector needs to be lifted up and not being pulled to the side.
      • Now you can pry out the battery which is glued in with double sided adhesive tape.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
16 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
134.831 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.573 handleidingen geschreven
44Gids Commentaar
This is great. What type of battery is the replacement?? thanks!
TrustNoShadows - Antwoord Deel
Hi, thanks for the question. I added another picture and put some information in the introduction.
Tobias Isakeit - Antwoord Deel
hey, thanks for this! is the battery plug simple JST or do I need to get something specific?
lfsaw - Antwoord Deel
Yes, a simple JST plug (probably type ACH)
Thanks for posting these instructions! I'm having trouble finding a battery that matches the one in the picture (unless I want to buy 1000 of them from Alibaba). Would this work?
http://www.ebay.com/itm/3-7V-1800mAh-Rec...
Dimensions are:
thick:3mm
wide:60mm
length:70mm
Clarke Robinson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 26
Afgelopen 7 dagen: 142
Afgelopen 30 dagen: 512
Altijd: 48,897
