Ga door naar hoofdinhoud
Teddy Ruxpin Arm Button Replacement
Wat je nodig hebt
    1. Teddy Ruxpin Arm Button Replacement, Battery: stap 1, afbeelding 1 van 2 Teddy Ruxpin Arm Button Replacement, Battery: stap 1, afbeelding 2 van 2
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Arm Button Replacement: stap 2, afbeelding 1 van 1
      • Pull the tab outward to remove the protective plate for the batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. Teddy Ruxpin Arm Button Replacement: stap 3, afbeelding 1 van 1
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Arm Button Replacement, Arms: stap 4, afbeelding 1 van 3 Teddy Ruxpin Arm Button Replacement, Arms: stap 4, afbeelding 2 van 3 Teddy Ruxpin Arm Button Replacement, Arms: stap 4, afbeelding 3 van 3
      • Cut the orange shirt and zip tie.
      • Remove the zip tie.
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Arm Button Replacement: stap 5, afbeelding 1 van 1
      • Cut across the back seam of the head of the bear along the arrow.
      • This damages the bear's exterior and will require resewing.
      Vraag FixBot
      Voeg opmerking toe
    3. Teddy Ruxpin Arm Button Replacement: stap 6, afbeelding 1 van 3 Teddy Ruxpin Arm Button Replacement: stap 6, afbeelding 2 van 3 Teddy Ruxpin Arm Button Replacement: stap 6, afbeelding 3 van 3
      • Remove the interior of the doll.
      • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
      • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
      Vraag FixBot
      Voeg opmerking toe
    4. Teddy Ruxpin Arm Button Replacement: stap 7, afbeelding 1 van 2 Teddy Ruxpin Arm Button Replacement: stap 7, afbeelding 2 van 2
      • Extract each arm button.
      • Pull on the stuffing of the bear and not the wire to remove the arm button.
      Vraag FixBot
      Voeg opmerking toe
    5. Teddy Ruxpin Arm Button Replacement: stap 8, afbeelding 1 van 2 Teddy Ruxpin Arm Button Replacement: stap 8, afbeelding 2 van 2
      • Pull off the rest of the outside layer of the bear.
      Vraag FixBot
      Voeg opmerking toe
    6. Teddy Ruxpin Arm Button Replacement: stap 9, afbeelding 1 van 1
      • Unplug the arms from the main body.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Lauren
226 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2020 Lid van Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Leden
8 handleidingen geschreven
4Gids Commentaar
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - Antwoord Deel
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - Antwoord Deel
So has anyone figured out how to replace the button?
knrobinson83 - Antwoord Deel
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 1,523
