Ga door naar hoofdinhoud
Teddy Bear Nose Replacement
Wat je nodig hebt
  1. Teddy Bear Nose Replacement, Nose: stap 1, afbeelding 1 van 2 Teddy Bear Nose Replacement, Nose: stap 1, afbeelding 2 van 2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: stap 2, afbeelding 1 van 2 Teddy Bear Nose Replacement: stap 2, afbeelding 2 van 2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: stap 3, afbeelding 1 van 1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: stap 4, afbeelding 1 van 2 Teddy Bear Nose Replacement: stap 4, afbeelding 2 van 2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: stap 5, afbeelding 1 van 1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: stap 6, afbeelding 1 van 1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: stap 7, afbeelding 1 van 1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: stap 8, afbeelding 1 van 1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: stap 9, afbeelding 1 van 1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: stap 10, afbeelding 1 van 3 Teddy Bear Nose Replacement: stap 10, afbeelding 2 van 3 Teddy Bear Nose Replacement: stap 10, afbeelding 3 van 3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: stap 11, afbeelding 1 van 2 Teddy Bear Nose Replacement: stap 11, afbeelding 2 van 2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Eindstreep
Nazib Khan
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 115
Altijd: 4,008
