Ga door naar hoofdinhoud
How to Sew a Whip Stitch
Wat je nodig hebt
  1. How to Sew a Whip Stitch, How to Sew a Whip Stitch: stap 1, afbeelding 1 van 2 How to Sew a Whip Stitch, How to Sew a Whip Stitch: stap 1, afbeelding 2 van 2
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. How to Sew a Whip Stitch: stap 2, afbeelding 1 van 3 How to Sew a Whip Stitch: stap 2, afbeelding 2 van 3 How to Sew a Whip Stitch: stap 2, afbeelding 3 van 3
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. How to Sew a Whip Stitch: stap 3, afbeelding 1 van 3 How to Sew a Whip Stitch: stap 3, afbeelding 2 van 3 How to Sew a Whip Stitch: stap 3, afbeelding 3 van 3
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. How to Sew a Whip Stitch: stap 4, afbeelding 1 van 2 How to Sew a Whip Stitch: stap 4, afbeelding 2 van 2
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. How to Sew a Whip Stitch: stap 5, afbeelding 1 van 2 How to Sew a Whip Stitch: stap 5, afbeelding 2 van 2
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. How to Sew a Whip Stitch: stap 6, afbeelding 1 van 3 How to Sew a Whip Stitch: stap 6, afbeelding 2 van 3 How to Sew a Whip Stitch: stap 6, afbeelding 3 van 3
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. How to Sew a Whip Stitch: stap 7, afbeelding 1 van 1
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
Eindstreep
19 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.113 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.892 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 96
Altijd: 39,908
