Ga door naar hoofdinhoud
TI-36X Pro Button Replacement
Wat je nodig hebt
    1. TI-36X Pro Button Replacement, Back Cover: stap 1, afbeelding 1 van 2 TI-36X Pro Button Replacement, Back Cover: stap 1, afbeelding 2 van 2
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      Vraag FixBot
      Voeg opmerking toe
    2. TI-36X Pro Button Replacement: stap 2, afbeelding 1 van 2 TI-36X Pro Button Replacement: stap 2, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      Vraag FixBot
      Voeg opmerking toe
    1. TI-36X Pro Button Replacement, Battery: stap 3, afbeelding 1 van 2 TI-36X Pro Button Replacement, Battery: stap 3, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
      • Remove the battery cover without disconnecting either end of the blue wire.
      • Use your finger to move the battery cover to the side.
      Vraag FixBot
      Voeg opmerking toe
    2. TI-36X Pro Button Replacement: stap 4, afbeelding 1 van 1
      • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
      • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
      Vraag FixBot
      Voeg opmerking toe
    1. TI-36X Pro Button Replacement, Button: stap 5, afbeelding 1 van 1
      • After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
      • Do not disconnect any wires or you will need to solder them back on.
      Vraag FixBot
      Voeg opmerking toe
    2. TI-36X Pro Button Replacement: stap 6, afbeelding 1 van 1
      • Next, use a Phillips #00 screwdriver to remove the two screws located on each side of the striped ribbon between the two green circuit boards.
      Vraag FixBot
      Voeg opmerking toe
    3. TI-36X Pro Button Replacement: stap 7, afbeelding 1 van 1
      • Be careful not to scratch the gold lines on the circuit board since it may damage the circuit.
      • Carefully chisel off the 11 circular pieces that connect the lower circuit board to the calculator.
      • When reassembling the calculator, glue the lower circuit board back in place by dabbing glue into the holes that you chiseled.
      Vraag FixBot
      Voeg opmerking toe
    4. TI-36X Pro Button Replacement: stap 8, afbeelding 1 van 3 TI-36X Pro Button Replacement: stap 8, afbeelding 2 van 3 TI-36X Pro Button Replacement: stap 8, afbeelding 3 van 3
      • When removing the parts from the calculator be careful not to break any wires or ribbons. The solar panel, screen, and lower circuit board should remain connected throughout this guide.
      • Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
      • Carefully pry the screen out of the calculator with a prying tool or spudger.
      • Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    5. TI-36X Pro Button Replacement: stap 9, afbeelding 1 van 1
      • Grab one of the top corners of the gray rubber button pad and peel it off of the buttons.
      • If you turn the calculator over, all of the buttons will fall out.
      Vraag FixBot
      Voeg opmerking toe
    6. TI-36X Pro Button Replacement: stap 10, afbeelding 1 van 2 TI-36X Pro Button Replacement: stap 10, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Locate the button that needs replacement and lift it out of the calculator with tweezers.
      • If the buttons do fall out, use the second picture to put them back properly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Robert Sekerak
664 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-52, Amido Spring 2014 Lid van Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 Leden
25 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 44
Altijd: 3,076
