Ga door naar hoofdinhoud
TDK Life on Record Trek Max A34 Motherboard Replacement
Wat je nodig hebt
  1. TDK Life on Record Trek Max A34 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 2, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 3, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 3, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 4, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • The battery is now separated from the device and may be replaced with a new battery.
  6. TDK Life on Record Trek Max A34 Motherboard Replacement, Large Speaker: stap 6, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement, Large Speaker: stap 6, afbeelding 2 van 2
    • Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
    • Remove the battery cover by pulling up where the screws should go.
  7. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 7, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Carefully unplug and remove the battery.
    • Use the metal spudger to pry off the rubber bumpers from the bottom of the speaker.
  8. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 8, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 8, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the screws that were underneath the rubber bumpers.
    • Remove the battery holder. Be sure to thread the exposed wires through the hole within the holder.
  9. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 9, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 9, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it more easily.
  10. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 10, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 10, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Turn the speaker back upright. Use the metal spudger to pry up the rubber cover to reveal the buttons underneath.
  11. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 11, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the screws that hold the top cover in place.
    • Remove the top cover.
  12. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 12, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • On the backside of the device, remove the screws using the Phillips #0 screwdriver.
    • Only the screws on the backside are needed to hold the frame together. Do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  13. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Within the device, there is a single cable connecting the large speaker to the motherboard. Unplug this cable.
  14. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 14, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • On the front of the device, use the Phillips #0 screwdriver to remove the four screws holding the speaker in.
    • Once the screws are removed, you are able to push the speaker out from behind.
  15. TDK Life on Record Trek Max A34 Motherboard Replacement, Small Speaker: stap 15, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement, Small Speaker: stap 15, afbeelding 2 van 2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  16. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 16, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  17. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 17, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 17, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  18. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 18, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 18, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  19. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 19, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 19, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 19, afbeelding 3 van 3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  20. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 20, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
  21. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 21, afbeelding 1 van 2 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 21, afbeelding 2 van 2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
  22. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 22, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 22, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement: stap 22, afbeelding 3 van 3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
  23. TDK Life on Record Trek Max A34 Motherboard Replacement, Motherboard: stap 23, afbeelding 1 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement, Motherboard: stap 23, afbeelding 2 van 3 TDK Life on Record Trek Max A34 Motherboard Replacement, Motherboard: stap 23, afbeelding 3 van 3
    • Carefully detach the 4 white rectangular clips from the motherboard.
  24. TDK Life on Record Trek Max A34 Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Carefully remove the motherboard from the device.
Conclusie
Marilyn Ho
211 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Harley Fall 2019 Lid van IUPUI, Team S1-G3, Harley Fall 2019
IUPUI-HARLEY-F19S1G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 588
