Ga door naar hoofdinhoud
T-Mobile Sparq Screen Cover Replacement
Wat je nodig hebt
    1. T-Mobile Sparq Screen Cover Replacement, Battery: stap 1, afbeelding 1 van 1
      • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
      • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. T-Mobile Sparq Screen Cover Replacement: stap 2, afbeelding 1 van 1
      • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
      • Insert the tip of your finger into the groove and gently lift the battery from the case.
      Vraag FixBot
      Voeg opmerking toe
    1. T-Mobile Sparq Screen Cover Replacement, Speaker: stap 3, afbeelding 1 van 1
      • There are eight 2mm screws that must be removed from the back of the device using a Phillips #000 screwdriver. As you remove them it is wise to organize them into a small container or place them on a magnetic project mat for safe keeping.
      Vraag FixBot
      Voeg opmerking toe
    2. T-Mobile Sparq Screen Cover Replacement: stap 4, afbeelding 1 van 2 T-Mobile Sparq Screen Cover Replacement: stap 4, afbeelding 2 van 2
      • Once the screws have been removed from the back of the device turn it back over.
      • The keypad that is seated within the bottom phone case can now be removed. If you have trouble getting the keypad out you may use a spudger to gently pry it.
      Vraag FixBot
      Voeg opmerking toe
    3. T-Mobile Sparq Screen Cover Replacement: stap 5, afbeelding 1 van 3 T-Mobile Sparq Screen Cover Replacement: stap 5, afbeelding 2 van 3 T-Mobile Sparq Screen Cover Replacement: stap 5, afbeelding 3 van 3
      • Once the back case has been removed, gently lift the motherboard away from the phone keypad - do not yank. There is an electronic ribbon connecting the board to the other side of the phone.
      • Once you've identified the ribbon, gently pull the ribbon at the end connected to the motherboard until it comes off. It's sort of like an electronic lego - it will snap off of the board without much applied pressure.
      Vraag FixBot
      Voeg opmerking toe
    4. T-Mobile Sparq Screen Cover Replacement: stap 6, afbeelding 1 van 3 T-Mobile Sparq Screen Cover Replacement: stap 6, afbeelding 2 van 3 T-Mobile Sparq Screen Cover Replacement: stap 6, afbeelding 3 van 3
      • There are six 2mm screws that connect the keypad piece to the other side of the phone. Using a Phillips #000 screwdriver, remove those screws and separate the two sides of the phone.
      Vraag FixBot
      Voeg opmerking toe
    5. T-Mobile Sparq Screen Cover Replacement: stap 7, afbeelding 1 van 3 T-Mobile Sparq Screen Cover Replacement: stap 7, afbeelding 2 van 3 T-Mobile Sparq Screen Cover Replacement: stap 7, afbeelding 3 van 3
      • Remove the 5 screws from the back plate on the front piece of the phone.
      • Once those screws have been removed you should be able to separate the silver plastic piece from the front cover. If it sticks you may need to use a spudger or similar tool to help you get started.
      Vraag FixBot
      Voeg opmerking toe
    6. T-Mobile Sparq Screen Cover Replacement: stap 8, afbeelding 1 van 2 T-Mobile Sparq Screen Cover Replacement: stap 8, afbeelding 2 van 2
      • You will see an orange electronic ribbon cable running from the green board at the bottom of the phone, over the back of the screen and finally attached to a metal cover that hides the ear speaker.
      • To remove the metal cover from the speaker, first take a close look at how it is connected to the phone. There are two metal prongs that hold the cover in place.
      • Use the thin end of a tool, like a spudger, to gently depress the prongs and simultaneously lift the cover off of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    7. T-Mobile Sparq Screen Cover Replacement: stap 9, afbeelding 1 van 2 T-Mobile Sparq Screen Cover Replacement: stap 9, afbeelding 2 van 2
      • Voila! You now have access to the speaker. The face of the speaker is lightly adhered to the plastic case. Use the spudger to gently lift it from the plastic casing.
      Vraag FixBot
      Voeg opmerking toe
    1. T-Mobile Sparq Screen Cover Replacement, Screen Cover: stap 10, afbeelding 1 van 2 T-Mobile Sparq Screen Cover Replacement, Screen Cover: stap 10, afbeelding 2 van 2
      • The full screen/motherboard assembly simply comes out of the front case. If you have some difficulty removing it, you may use a thin tool (like a spudger) to help you lift it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
LeAnn Lewis
539 Reputatie
4 handleidingen geschreven
IUPUI, Team S3-G3, Wilson Spring 2018 Lid van IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Leden
32 handleidingen geschreven
1Gids Commentaar
Is there a screen replacement step by step for this phone? please and thank you
LiMNisALIVE ALIVEisLiMN - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 762
