Ga door naar hoofdinhoud
T-Mobile Sparq SIM Card Replacement
Wat je nodig hebt
  1. T-Mobile Sparq SIM Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. T-Mobile Sparq SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
    Vraag FixBot
    Voeg opmerking toe
  3. T-Mobile Sparq SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Once the battery has been removed the SIM card is easily accessible. Press your finger gently on top of the exposed SIM card and slide it in the direction of the battery compartment until it comes out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
LeAnn Lewis
539 Reputatie
4 handleidingen geschreven
IUPUI, Team S3-G3, Wilson Spring 2018 Lid van IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 31
Altijd: 517
