Ga door naar hoofdinhoud
Syma S107 Gyro Replacement
Wat je nodig hebt
  1. Syma S107 Gyro Replacement, Counterweight Bar: stap 1, afbeelding 1 van 2 Syma S107 Gyro Replacement, Counterweight Bar: stap 1, afbeelding 2 van 2
    • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
  2. Syma S107 Gyro Replacement: stap 2, afbeelding 1 van 2 Syma S107 Gyro Replacement: stap 2, afbeelding 2 van 2
    • Remove the counterweight bar by removing the screw.
    • One 10.1mm Phillips #0.
  3. Syma S107 Gyro Replacement, Gyro Carriage: stap 3, afbeelding 1 van 2 Syma S107 Gyro Replacement, Gyro Carriage: stap 3, afbeelding 2 van 2
    • Remove the gyro carriage by removing the following screws:
    • Two 5.6mm Phillips #0.
    • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
  4. Syma S107 Gyro Replacement: stap 4, afbeelding 1 van 2 Syma S107 Gyro Replacement: stap 4, afbeelding 2 van 2
    • Gently remove the broken gyro carriage by pulling up.
    • Remove blade assembly by simply sliding it up and off the shaft.
  5. Syma S107 Gyro Replacement, Blade Carriage: stap 5, afbeelding 1 van 3 Syma S107 Gyro Replacement, Blade Carriage: stap 5, afbeelding 2 van 3 Syma S107 Gyro Replacement, Blade Carriage: stap 5, afbeelding 3 van 3
    • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
  6. Syma S107 Gyro Replacement: stap 6, afbeelding 1 van 2 Syma S107 Gyro Replacement: stap 6, afbeelding 2 van 2
    • Remove the blades from the blade carriage by removing the following screws:
    • Two 4.7mm Phillips #0.
  7. Syma S107 Gyro Replacement: stap 7, afbeelding 1 van 2 Syma S107 Gyro Replacement: stap 7, afbeelding 2 van 2
    • Remove the following screws:
    • Two 4.5mm Phillips #0.
    • Make sure to remove any broken plastic pins before reassembling the components.
    • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Christopher Smith
305 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-31, Donnelly Fall 2014 Lid van USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 Lid
1 handleiding geschreven
6 opmerkingen
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Antwoord
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Antwoord
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Antwoord
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Antwoord
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Antwoord
Now it flies in an oval pattern wat am I doing wrong?
prober1212 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 47
Altijd: 14,235
