Ga door naar hoofdinhoud
Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
Wat je nodig hebt
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: stap 1, afbeelding 1 van 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: stap 1, afbeelding 2 van 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: stap 1, afbeelding 3 van 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: stap 4, afbeelding 1 van 2 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: stap 4, afbeelding 2 van 2
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: stap 5, afbeelding 1 van 1
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Logan Sluder
562 Reputatie
6 handleidingen geschreven
1Gids Commentaar
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 1,579
