Ga door naar hoofdinhoud
Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
Wat je nodig hebt
  1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: stap 1, afbeelding 1 van 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: stap 1, afbeelding 2 van 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: stap 1, afbeelding 3 van 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: stap 2, afbeelding 1 van 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: stap 4, afbeelding 1 van 1
    • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
  5. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: stap 5, afbeelding 1 van 2 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: stap 5, afbeelding 2 van 2
    • Release the clip connection connecting the LED ring to the motherboard.
    • Remove the infrared LED assembly.
Conclusie
Logan Sluder
580 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 40
Altijd: 1,672
