Ga door naar hoofdinhoud
Swagtron T3 Wheel Replacement
Wat je nodig hebt
    1. Swagtron T3 Wheel Replacement, Cover: stap 1, afbeelding 1 van 2 Swagtron T3 Wheel Replacement, Cover: stap 1, afbeelding 2 van 2
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    2. Swagtron T3 Wheel Replacement: stap 2, afbeelding 1 van 3 Swagtron T3 Wheel Replacement: stap 2, afbeelding 2 van 3 Swagtron T3 Wheel Replacement: stap 2, afbeelding 3 van 3
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Swagtron T3 Wheel Replacement, Wheel: stap 3, afbeelding 1 van 1
      • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
      • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
      Vraag FixBot
      Voeg opmerking toe
    2. Swagtron T3 Wheel Replacement: stap 4, afbeelding 1 van 2 Swagtron T3 Wheel Replacement: stap 4, afbeelding 2 van 2
      • Pull the wheel off of its base.
      • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Klara Perkins
412 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G3, Forte Spring 2017 Lid van Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Leden
4 handleidingen geschreven
3Gids Commentaar
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - Antwoord Deel
Can't the wheel off
Christopher Primo - Antwoord Deel
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 4,723
