Ga door naar hoofdinhoud
Swagtron T3 Battery Replacement
Wat je nodig hebt
    1. Swagtron T3 Battery Replacement, Cover: stap 1, afbeelding 1 van 2 Swagtron T3 Battery Replacement, Cover: stap 1, afbeelding 2 van 2
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    2. Swagtron T3 Battery Replacement: stap 2, afbeelding 1 van 3 Swagtron T3 Battery Replacement: stap 2, afbeelding 2 van 3 Swagtron T3 Battery Replacement: stap 2, afbeelding 3 van 3
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Swagtron T3 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
      • Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
      Vraag FixBot
      Voeg opmerking toe
    2. Swagtron T3 Battery Replacement: stap 4, afbeelding 1 van 2 Swagtron T3 Battery Replacement: stap 4, afbeelding 2 van 2
      • Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
      • One red and black cable with a yellow connector.
      • One blue cable with a black connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Swagtron T3 Battery Replacement: stap 5, afbeelding 1 van 2 Swagtron T3 Battery Replacement: stap 5, afbeelding 2 van 2
      • Remove the battery by pulling it out from under the cables.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Neeki Jarrami
197 Reputatie
1 Handleiding geschreven
Cal Poly, Team S13-G3, Forte Spring 2017 Lid van Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Leden
4 handleidingen geschreven
11Gids Commentaar
where can i get a replacement battery?
rob - Antwoord Deel
Where can I get a replacement battery?
rob - Antwoord Deel
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Jeff Johnson - Antwoord Deel
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Leandre Thornton - Antwoord Deel
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
Daniel Moravec - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 66
Altijd: 8,979
