Ga door naar hoofdinhoud
SwagTron T1 Wheel Replacement
Wat je nodig hebt
  1. SwagTron T1 Wheel Replacement, Back Panels: stap 1, afbeelding 1 van 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
    Vraag FixBot
    Voeg opmerking toe
  2. SwagTron T1 Wheel Replacement: stap 2, afbeelding 1 van 3 SwagTron T1 Wheel Replacement: stap 2, afbeelding 2 van 3 SwagTron T1 Wheel Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    Vraag FixBot
    Voeg opmerking toe
  3. SwagTron T1 Wheel Replacement: stap 3, afbeelding 1 van 3 SwagTron T1 Wheel Replacement: stap 3, afbeelding 2 van 3 SwagTron T1 Wheel Replacement: stap 3, afbeelding 3 van 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Vraag FixBot
    Voeg opmerking toe
  4. SwagTron T1 Wheel Replacement, Wheel: stap 4, afbeelding 1 van 3 SwagTron T1 Wheel Replacement, Wheel: stap 4, afbeelding 2 van 3 SwagTron T1 Wheel Replacement, Wheel: stap 4, afbeelding 3 van 3
    • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
    • Carefully remove this component and set it off to the side.
    Vraag FixBot
    Voeg opmerking toe
  5. SwagTron T1 Wheel Replacement: stap 5, afbeelding 1 van 3 SwagTron T1 Wheel Replacement: stap 5, afbeelding 2 van 3 SwagTron T1 Wheel Replacement: stap 5, afbeelding 3 van 3
    • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
    • Take off the iron plate holding the wheel in place.
    • Remove the Motor/Wheel and set it aside close by to the hoverboard.
    • The wires from the Motor/Wheel should still be connected to the motherboard.
    • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
    Vraag FixBot
    Voeg opmerking toe
  6. SwagTron T1 Wheel Replacement: stap 6, afbeelding 1 van 3 SwagTron T1 Wheel Replacement: stap 6, afbeelding 2 van 3 SwagTron T1 Wheel Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
    • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
    • Separate the set of marked green, blue, and yellow wires from their connectors.
    Vraag FixBot
    Voeg opmerking toe
  7. SwagTron T1 Wheel Replacement: stap 7, afbeelding 1 van 3 SwagTron T1 Wheel Replacement: stap 7, afbeelding 2 van 3 SwagTron T1 Wheel Replacement: stap 7, afbeelding 3 van 3
    • Finally separate the last connector shown on the left.
    • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
    • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Teagan Allen
432 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G5, Banghart Spring 2017 Lid van Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Leden
5 handleidingen geschreven
3Gids Commentaar
Where do you get replacement wheels?
Elizabeth Schumacher - Antwoord Deel
Where can we find replacement wheels?
Liz Vance - Antwoord Deel
Mine won't stop beeping?? Fully charged.
Rachael Anderson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 6,586
