Ga door naar hoofdinhoud
SwagTron T1 Gyroscope Replacement
Wat je nodig hebt
  1. SwagTron T1 Gyroscope Replacement, Back Panels: stap 1, afbeelding 1 van 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
    Vraag FixBot
    Voeg opmerking toe
  2. SwagTron T1 Gyroscope Replacement: stap 2, afbeelding 1 van 3 SwagTron T1 Gyroscope Replacement: stap 2, afbeelding 2 van 3 SwagTron T1 Gyroscope Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    Vraag FixBot
    Voeg opmerking toe
  3. SwagTron T1 Gyroscope Replacement: stap 3, afbeelding 1 van 3 SwagTron T1 Gyroscope Replacement: stap 3, afbeelding 2 van 3 SwagTron T1 Gyroscope Replacement: stap 3, afbeelding 3 van 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Vraag FixBot
    Voeg opmerking toe
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: stap 4, afbeelding 1 van 2 SwagTron T1 Gyroscope Replacement, Gyroscope: stap 4, afbeelding 2 van 2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
    Vraag FixBot
    Voeg opmerking toe
  5. SwagTron T1 Gyroscope Replacement: stap 5, afbeelding 1 van 1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
    Vraag FixBot
    Voeg opmerking toe
  6. SwagTron T1 Gyroscope Replacement: stap 6, afbeelding 1 van 3 SwagTron T1 Gyroscope Replacement: stap 6, afbeelding 2 van 3 SwagTron T1 Gyroscope Replacement: stap 6, afbeelding 3 van 3
    • Carefully remove the gyroscope component from the SwagTron.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Teagan Allen
432 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G5, Banghart Spring 2017 Lid van Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Leden
5 handleidingen geschreven
5Gids Commentaar
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Antwoord Deel
Amazon.com Keyword: CertiCable
Jesse Griffis - Antwoord Deel
Where do you get the replacement?
Brittany Conner - Antwoord Deel
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Antwoord Deel
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 8,338
