Ga door naar hoofdinhoud
Supersonic Matrix SC-91MID Screen Replacement
Wat je nodig hebt
    1. Supersonic Matrix SC-91MID Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Supersonic Matrix SC-91MID Screen Replacement, Screen: stap 1, afbeelding 2 van 2
      • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section.
      • Be aware of the ribbon cables when removing the display screen from the main component.
      Vraag FixBot
      Voeg opmerking toe
    2. Supersonic Matrix SC-91MID Screen Replacement: stap 2, afbeelding 1 van 3 Supersonic Matrix SC-91MID Screen Replacement: stap 2, afbeelding 2 van 3 Supersonic Matrix SC-91MID Screen Replacement: stap 2, afbeelding 3 van 3
      • Place the plastic opening tool between the metal screen plate and the black front casing.
      • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Supersonic Matrix SC-91MID Screen Replacement: stap 3, afbeelding 1 van 3 Supersonic Matrix SC-91MID Screen Replacement: stap 3, afbeelding 2 van 3 Supersonic Matrix SC-91MID Screen Replacement: stap 3, afbeelding 3 van 3
      • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
      Vraag FixBot
      Voeg opmerking toe
    4. Supersonic Matrix SC-91MID Screen Replacement: stap 4, afbeelding 1 van 1
      • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Norikuni Nishikawa
139 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G1, Wilson Spring 2018 Lid van IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 615
