Inleiding
In this guide you will open the back cover and use a screwdriver to remove the camera from its housing.
Wat je nodig hebt
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
Remove the two Phillips #00 screws attaching the housing of the camera to the device.
Één andere persoon heeft deze handleiding voltooid.
