Inleiding
In this guide you will open up the back of the device and locate the 3.5mm headphone jack on the mother board. Once it is found you must remove it with a soldering iron and replace it.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Wat je nodig hebt
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
